  1. In the navigation pane, expand Configuration > Edit.
  2. Select VTEP.
  3. Select the Globals tab.
  4. In SourceIp, type the VTEP source IP address.
  5. In Vrf, select GlobalRouter or a VRF ID.
  6. Select Apply.
Use the data in the following table to use the Globals tab.
Name
Description
SourceIp
Specifies the VXLAN tunnel end point (VTEP) source IP address in an A.B.C.D format.
Vrf
Specifies the VRF name used for the source IP address, which you select from the drop down menu. This IP address can be on the GRT or a VRF.
Note:
The VTEP source IP address must be on a loopback interface.
